Parts available from 29th June
Pics and prices to come low Kim's r33 big turbo set up motor box Coilovers body kit plus more
All body panels straight in great condition
Pm your pre orders
Located Redhead nsw
1995 series 1 marroon
Just moved both my cars will be shipped next week i will upload pics and prices then
0402555849
I have a complete car here is the list if there is anything that you want thats not on the list just pm or call
Mechanical:
rb25det comp tested runs perfect will have clip of it running before removal. Comes complete with aftermarket coilpacks ecu wiring all accessories stock turbo but no turbo manifold $1200
Highmount turbo set up. T04e with manifold proboost external wastegate with screamer, braided lines, dump pipe,front mount plus all pipings ,clamps hks style bov $1350 All 18month old
r33 gearbox perfect conditon $1200
tein superstreets coilovers just over 12 month old $850
Complete front brake set up including hubs and knuckle $350
Rear set up including handbrake cables and hubs $350
R33 gtr radiator $200
Tight lsd $250
Rear shafts $65 each
Tail shaft $80
Front controll arms lower $45 each
Front caster arms $20 each
Rear complete arms $60 a side
Front and rear stock sways $45 each
P/s rack $80
Stock wheels 2 tyres ok missing 2 centre caps $200
Brake master cylinder $35
Booster $40
Rear supframe $120
Anything else just ask
Body:
Straight as guards $100 each
body kit included front bar which is cracked but can easily be repaired , side skirts and rear bar in good conditon $400
Rear boot with wing $200
Gtr boot with wing $300
Bonnet very straight $250
headlights will be glass polished before sent $250
rear tail lights $65 each
Straight as doors with windows regs no handles or trims $100 each
Mirrors $45 each
Interior:
neat front seats $150
Rear seats $75
door trims $50 each
stero surround $50
Cluster $100
Centre console $50
rear view mirror $35
Seat belts Front $45 each rears $60 the lot
autometer boost gauge with cup $45
turbo timer $35
Rear trims $25 a side
Pillar trims $15 each
Scuff panels $20 each
Dash $80
anything else just ask
0402555849 or pm
Located newcastle but can help with freight
Edited by runkos
Some new pics and prices
Unknown jap brand 3 inch front pipe $70
3 1/2 inch cat back into 4 inch diff back stainless exhaust with cannon $300
Tein non adjustable suspension $450
Manual conversion kit $1500
rb25det motor ecu wiring aftermarket coilpacks with t04e turbo set up including front mount and piping $2200.
I have a clip of it erunning before removal
Fuel flap $15
Boot rubber perfect condiotn $20
Skyline garnish $35
Rear window lower trim perfect condition $35
Spare tyre $50
Factory jack no handle $25
Edited by runkos
S1 R33 GTST Auto speed sensor by any chance?
No sorry mate
Will the hub + knuckle fit an R34 GTT?
Mine is broken and I can't find another.
Not sure have you asked any of the guys on here in tec section?
Motor sold
gearbox conversion sold
teins sold
Gtr boot sold
rear bar sold
rear seat belts sold
Still have heaps of interior bits, seats,driveshafts, wheels, exhaust , door skins, bonnet , passanger guard, skirts, gtr radiator and a few other bits and peices
Stolen car kit Boot lock , door locks , complete steering assembley with ignition barrel and key $110
  • 4 weeks later...
hey mate you got a pic of that boost gauge, i need a cheap one for testing! also is it psi?
psi mate
will you do 2 wheels for 80 cash?
Wheels sold
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
