Hello All,
Have some 17" Rays Gram Lights 57D for sale. Where on the car when i got it and have been great. Reason for sale is i have got 9" all round now so i can rotate wheel/tyres at the track.
They are:
17 x 8.5 +30 - 235/45 Federal RSR's - I would say around 70% tread.
17 x 9.5 +38 - 255/40 Federal RSR's - I would say around 50% tread.
Need to confirm offsets but i think thats what they are/can be bought off the shelf as.
Hardly any rash at all. Sorry i dont have close up pics. No dents or anyting like that. Perfectly balanced.
Photos are from R33 GTST. Fronts sit in a bit cause im running 4 deg neg camber.
Rears are about 1.5 deg neg camber.
I ran these with no guard rolling/flaring and they where fine. Did hit the plastic inner guard on full lock at the ride height i was at. Probably due to camber.
Plenty of clearance for brakes - Pics are 330mm 8 pot Ksport - plenty of room remaining.
Price - $1450
Location - Melbourne only - Pickup.
Email - [email protected]
Phone - 0420208177
Welcome to come and have a look and check them out. SE suburbs of Melbourne - Near Caulfiald.
Cheers,
Dave
post-4091-0-13830400-1340626808_thumb.jpgpost-4091-0-88071200-1340626825_thumb.jpgpost-4091-0-37719900-1340626856_thumb.jpgpost-4091-0-68933600-1340626890_thumb.jpgpost-4091-0-45553000-1340626915_thumb.jpgpost-4091-0-10730900-1340626951_thumb.jpgpost-4091-0-57310300-1340626978_thumb.jpg
https://www.sau.com.au/forums/topic/403409-rays-gram-lights-57d-17/
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
