hey guys i have up for sale the following two sets of wheels.
Wheel no1
Weds Kranze Lxz chrome finish.
18x9+22 f
18x10+31 r
wheels comes with tires around 70% tread. wheels are in good condition. no buckle or chunks missing from wheels. wheels do have your usual gutter rash.
Price $2600 ono. happy to send interstate at YOUR cost
wheel no2:
SSR professor ms1. these are EOI atm as im not 100% sure if i want to fit them to my car or not.
wheels are finished in hyperblack chrome.
specs:
19" x 9 offset +11 step lip
19" x 10 offset +11 step lip
wheels are in good condition. cpiple of minor chips here and there. one wheel has a slight rash. nothing deep. will see upon inspection.
dont have any pics of the actual wheel yet. will post up soon.
$3000 ono
thanks
Ash
Hey ash have a mate from JDMST thats keen on the MS1's are these the ones pictured here?
Where u located for trial fit?
http://www.skylinesaustralia.com/forums/topic/403213-nsw-fs-full-set-of-ssr-professor-ms1-hyperblack-chrome/
for sale: full set of SSR Professor MS1
specs:
19" x 9jj offset +11 NR with step lip
19" x 10jj offset +11 SL with step lip
hyper black colour with polished dish
condition of wheels is great with minor chip and mark here and there but nothing major.
there is one rash about 25cm from previous owner on one front wheel but is superficial and can be machined out easily (can arrange for this also), can arrange tyres also if need be.
RRP for these wheels are $900 per wheel before special coat and shipping
pics below are of the actual wheels on the car they were on (not a promo pic)
selling the set cheap for $2300 shipped anywhere in australia
pickup available also
please pm me
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
