here i am selling the parts off my track car which has only had 2 track days...
it came off a rb25 motor...
there is pritty much all the bolt on modification parts for sale
heres a list of most of the parts cause i cant remember it all:
garrett 30/76 turbo with a .6 rear $950 with lines to suit (braid/solid lines)
JJR manifold witht he ext. gate fitting
38m turbo smart waste gate
3" dump pipe to suit (to suit r31 skyline)
forward facing JJR plenum
ID 1000 injectors
turbo smart fuel reg
ebay top feel fuel rail to suit but middle been threaded for the return line
spit fire coil packs
prices will be negotiated when there is intrest in the parts
will sepreate and will sell as a full kit...
this kit made 320kw at the wheels (on e85 pump fuel winter blend)
please call for prices and for intrest of other parts u may want i havent listed...
reasonable offers accepted...
NOTE: as i am rarley on the computer please text or call me as i will prob not reply to people on here..
located in sydney area castle hill
Michael 0401 346 630
Edited by r31drift
il take a pic of the dyno shoot out sheet next time im with the car,
fuel reg $160
modified rail with o rings etc $100
braided lines to suit e85 with fittings to suit - work out that depending on what you need if you come and take a look at the parts
  • 7 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
