Hey,
I just took a look at a 300GT pretty recently and planning to buy it very soon, I was just wondering how much do you guys pay for comprehensive or third party insurance? and which company? Also how old?
Thanks,
Richard
I did an online quote with justcars and they want something ridiculous like 6.5k
Edited by itsRICHARD
https://www.sau.com.au/forums/topic/403843-v35-300gt-insurance/
Forgot to mention that the 2004 Nissan Skyline 300GT isn't listed on most insurance companies online quote, so I would have to call them up, will get to that sometime today. Also I'm from VIC Melbourne.
Firstly about your car, have you considered the 350GT..?
I purchased my 2003 350GT Coupe around 3 months ago and went through RACQ Insurance (QLD) and i'm paying around 2k for a year (180 per month) for full comp insurance.
Now when you go to insure your car you need to tell them straight away it's an Import, or else they will spend hours at their computer thinking "i can't find his car anywhere". Once i told the lady who sorted my insurance it was an import, she sorted it straight away. My exess is very high though because i've lost my lisense before and i'm under 21, if you buy one of these cars mate don't drive like a wanker because if you prang it you're going to have a hard time getting someone to fix it unless there are a number of Import based workshops in your town that can supply parts for these cars because basically anything you want for them has to come from Japan/US. I've avoided going through Nissan for basically everything because the term "Stealership" is basically spot on..
But in saying all that, my 350GT is by far the best thing i've ever bought. Goodluck hope this helped.
The search button at the top can be helpful.
http://www.skylinesaustralia.com/forums/topic/174442-v35-insurance/page__st__180__p__6366708__hl__insurance__fromsearch__1#entry6366708
Heaps of info in this thread on exactly this topic.. insurance premiums are very dependant on your age, driving history and which insurer you choose.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
