For those people who own a series ONE sedan (01-04) and is looking for a nice simple bodykit but the wanderous kit is to ugly, the nismo is to hard to get and the American ones too tacky well if you have the money I have the answer....(will put up pictures later) I give to you the full four piece WALD kit from Japan for a (I think) reasonable $2500 shipped from Japan. This is genuine WALD not the cheap flimsy crap
For more info contact Jesse streeter
https://www.sau.com.au/forums/topic/403977-series-one-sedan-owners/
definitely the best looking "proper" body addition ive seen for the sedan tho. keeping the original bumpers just looks so much cleaner than all those other full kits
i'd also make sure that it is to suit the JDM version rather than the USDM which has longer bumper bars
Edited by Deep Dish V35
