These are near new 6piston Alcon calipers with 90% ferodo ds2500 pads.
They take a 380x36mm rotor
The rotors supplied are to suit a VE Holden Comodore which you may be able to redrill. Thu are single piece.
Adaptors supplied are also to suit a VE Comodore. But the calipers are radial mounted.
I want a quick easy sale of $2500 for the lot which is half what they are worth new.
Photos up latter today
Pick up from Campbeltown, postage is expensive due to rotor weight
https://www.sau.com.au/forums/topic/404155-6-piston-alcon-brakes/
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
