Hey guys thought I'd see if anyone in Canberra wants this stuff before I put it up in the for sale section. Now that I've sold my GTR I don't need this stuff anymore.
N1 rb26 block. Will need a clean up. Was part of my engine when it spun a bearing. I haven't had it checked out since it was pulled apart in December last year. Was planning on reusing it but sold the car without it. So am unsure of exactly what condition it's in. Had just over 25,000kms on it. Will let it go for $500.
Rb26 head with everything except cams, cam gears and cam, cam gear covers. Part of the same engine as the block so planned on reusing it also. Had been reconditioned. Still has intake and exhaust manifolds attached. Chasing $500 also.
Grex cams. Can get exact specs if you'd like. All I know is that they don't make these anymore. We're again part of the same engine. Will be happy with $250 for them.
Rb26 sump/diff with tomei baffle $150
R33 rb26 crankshaft. Was brand new when engine was built so only done about 25,000kms. As the engine spun a bearing it will need a clean up, haven't had it checked out so unsure of exact condition. $200
Probably have a few random little rb26 bits as well so if you need anything just ask. Am hopefully going to be taking photos on my day off on Wednesday. Any questions just pm me or SMS me as I work pretty long hours so will call you back as soon as I can :)
Cheers guys,
Drew 0433414424 :D
https://www.sau.com.au/forums/topic/404346-rb26-block-head-and-bits-for-sale/
  • 1 month later...
hey I'm keen on the head if its not sold yet? Its for an RB30 im building at the moment all i have is the block and sump so need all the covers and that too!
Hey mate, sorry you just missed out. Sold the complete head to a mate at work last week.
Only think I really have left now is the r33 crank
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
