Got some 33 stuff sitting around that i was going to use on my car.. decided on other things so they have to go, they are brand new unless otherwise stated..
r33 gtst RDA slotted rotors - just the fronts, barely used, were on my mates car whilst it was being built, then tuned, then the car was off the road, so were basically never used.. - chasing $120 ono
r33 gtst Project Mu Type HC+, Brand NEW!!! rears only, they retail for $200 plus shipping, im chasing $180 delivered
http://www.nengun.com/project-mu/brake-pads-type-hc-plus - link to what they are
r33 gtst clusters, random numbers on them, various conditions, none of them have cracks though, just a few light scratches on the surface but otherwise fine.. odo reads 116, 76, and 113 accordingly, all gauges work, $80 each delivered. They seem to be over $100 on ebay and the likes so thats cheap as chips delivered!!!
r33 gtst Stock Aero Side Skirts, EXCELLENT condition, no cracks or smashes or anything, check the pic out for the condition of them, mint as FARK.. chasing 150 ono..
Rays 57d's in fluro yellow.. 18 x 9.5, 2 of them are +12 and 2 of them are +22.. have been used on a drift car, but they are still in awesome condition, no chips, paint hasnt faded on them, and they come with BRAND NEW tyres, Gemstones on the front and Achilles sports on the rear, as i said, BRAND NEW, tyres are worth almost $800 alone,
Chasing $2200 Delivered Aus wide for them..
JDM styles train hang ring things.. be a JDM god and hang these from the towpoint of your car, bitches love that shit, $50 delivered Aus wide..
Located in Townsville, NQ.. I regularly use E-go for shipping so its generally cheap as chips, if you pay the prices i am asking i will organise and pay for shipping, but if you want to lowball me go ahead, but you will have to pay for shipping as i am not interested in getting jewed..
Cheers boys..
Chad - Rotors are sold pending payment, if this lad doesnt come through with the cash your next in line, then 33VOM if he ever gets his shit together.. :P
and nah bro, i imagine you'd need a HUUUGE chunk of cash ontop for the 57D's.. those XXR's are cheap as chips if you know where to get them from.. ;)
here's the best i can do man, these wheels are off an S15..
Here's my mates 33 though with the exact same wheel size, just obviously these are the orange ones from the range..
edit: i found one of it sitting still.. exact same wheel size.. :)
Edited by iadore4door34s
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
