Fs: [Syd] 2X Lasers, Fdd, Lpt, Molex, Dvi, S-Video, A/v, Power, Hsf Bracket Cables, Fan Grills
Hopefully it sells on this adult forums, I put it on OCAU and wasted my time with stupid excuses like my mum can't drive me, etc.
Notes:
  • Pickup is in NSW, 2165
  • Not Posting
  • Hopefully should be much easier now since school holidays are over
  • Selling in Lots of 1 and 2, cbf splitting
Lot 1:
Item 1: Black Floppy Disk Drive & Ribbon Cable
Item 2: Molex Female Power
Item 3: LPT Printer Cable (It's called LPT right? forgot)
Item 4: ~1.2 metres of Coxial Cable
Item 5: DVI Cable
Item 6: Power Cable
Item 7: OEM XBOX Scart Adaptor to Stereo A/V (works with other sht)
Item 8: S-Video -> Composite (New)
Item 9: A/V Cable
Item 10: S-Video -> S-Video (New)
Item 11: S-Video -> RCA
Item 12: S-Video -> S-Video
Item 13: DVI Cable (New)
Item 14: 3x Pack Power Cables has the 2x Circle Prong, Funny Euro & Au Plug
Item 15: AMD Socket 754 Fluro HSF Bracket Thing, Reacts to UV from DFI Lanparty
Item 16: Molex -> 2x SATA (New)
Item 17: 8cm Copper Fan Guard/Grill
Item 18: 2x 8cm Swooshy Looking Fan Guard/Girll
Item 19: Wannabe Zalman GPU Cooler, Variable Mounting width
Item 20: Zalman Passive North Bridge Cooler
Item 21: Gigabyte OEM Northbridge Cooler
Lot 2:
Item 1: Fuji Xerox P205b Laser Mono with depleted Toner
Item 2: Fuji Xerox P205b Laser Mono with depleted Toner + Box/Power Cables/USB/Driver CD/Box/Manuals
Instant: $10 for everything, Lots 1 & 2
__________________
  • 3 weeks later...
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
