hi guys im after sum help/info on a exedy xtreme daiken clutch part no: R5028NHD.
my car runs 210kw and just want to know if this will be ok to use and handle the power?ive searched google and the exedy website and i cant find out much about it so any help would be great
this is the only info i could find:
There are two heavy duty organic kits. First one is part no:
( R5028NHD ). Which is a new assembly the cover is pivot modified for increased clamp
https://www.sau.com.au/forums/topic/405267-r33-daiken-clutch-r5028nhd-infohelp/
Just when you think life has become easy by having all the information provided, someone pops a curve ball at you and you scratch your head
The NSK-7056HD is the only Heavy duty part number Exedy list. There are sports organics and other heavy duty options but they are all 7056 except the Hyper metal range. Your part number is incorrect.
Get the NSK-7056HD - it will serve you well at those power levels - as has been mentioned dozens and dozens of times on this site
The part number is correct but it is a daiken part number and now that exedy has taken over daiken id say they have changed them all so i might have to ring exedy and see if they have a cross reference to the old numbers
You are referring to a part number that is something like 15 years old. NSK-7056HD is the current number.
NSD-098U clutch plate was in the R5028NDH kits (over 10 years ago). These days you can save some money and buy the NSK-6797HD kit which will do the same thing
ok cool cause the clutch kit i have is brand new and the clutch plate in the box is part no:nsd-098u which is in the r5028ndh kit.sorry mate i was under the impression that exedy had taken over i wasnt tryn to be a smart ass.so is the clutch kit i have any good?will it last a while and will i be expecting a heavy peddle?thanks heaps for the info uve been a great help.
I know you're not being a smart ass. That part number is not one used by anyone any more - although some catalogues still contain the old numbers for this reason I think.
The clutch you have should be ok for 240-250rwkw safely for a few years. Pedal feel should be heavier than standard and definitely a lot heavier than your worn out standard clutch
i have a exedy cushon button clutch at the moment will peddle feel be similar?will this suit my r33 cause the nsk 6797 exedy clutch u are referring to on the exedy website says it is suitable for r31 and r32 but not mine.sorry for all the questions
Yes the pedal feel will be similar pressure but slightly less bitey than the cushion button.
The NSK-6797 is exactly the same clutch but the centre hub has large single springs from memory. The NSD-098U clutch plate has smaller double springs in the hub.
It could be the other way around though it's been a while since I cared enough to look. Both are equally as good and both will hold the same power. The double spring one is softer to drive on compared to the heavier single spring variety but it's really not noticeable
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
