here's the link
http://www.ebay.com.au/itm/320533465804?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1749wt_1037
check out my post on "what have you done on your stagea lately", post #4569 for pics on the different length, just need to cut about 3mm
https://www.sau.com.au/forums/topic/405351-m35-rack-ends/#findComment-6456235
  • 1 year later...
Hey guys, adambruv on the forum here linked me to these tie rod ends to suit M35 AWD (on the facebook page after I didnt have much success looking on here at the time - link above was no longer listed)
(originally for nissan 350z 03-09)
http://www.ebay.com.au/itm/170577303396?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
$55 free postage ! currently waiting for mine to be delivered so I can replace my shagged rack ends.
screenshot incase the link gets made redundant by the time you see this page
Few questions:
1) Do people really replace the ball joint only of the rack ends or do they buy replacements as I have done (found a few posts talking about rack ends then people linking lower ball joints only...)
2) Am I going to have to cut 3mm off as Sydsyd did on his 350z/g35 ones ? (a couple of posts above this)
3) Is there a difference between the 2WD and AWD tie rod ends? - Becuase I had a ebay seller say his 2WD tie rod ends will not suit AWD.
Thanks!
Edited by Dane
https://www.sau.com.au/forums/topic/405351-m35-rack-ends/#findComment-7259061
Here are the ones for "2WD only"
http://www.ebay.com.au/itm/2-OUTER-TIE-ROD-END-FOR-NISSAN-STAGEA-01-07-2WD-ONLY-/330859527586?pt=AU_Car_Parts_Accessories&fits=Model%3AStagea&hash=item4d08c3bda2
Screenshot
Note the seller names in both my screenshots.. Seems like same seller. And the product looks the same...But the seller advised this one for 2WD only as the add states as well.
https://www.sau.com.au/forums/topic/405351-m35-rack-ends/#findComment-7259090
Hope this helps you out...
Passenger Rack end - Nissan Japan Part Number: 49521KA - $114
Passenger Tie-rod end - Nissan Japan Part Number: 49520KA - $108AUD
Drivers Rack end - Nissan Japan Part Number: 49521K - $114
Drivers Tie-rod end - Nissan Japan Part Number: 49520K - $108AUD
https://www.sau.com.au/forums/topic/405351-m35-rack-ends/#findComment-7259837
Helps alot! I thought rack ends and tie rod ends were one and the same. Probably explains alot of my confusion lol Thanks very much for that info.
https://www.sau.com.au/forums/topic/405351-m35-rack-ends/#findComment-7264067
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
