Hey guys, first off im sincerly sorry if there is a specific WTB section but anyway.
I am chasing a Skyline as mentioned above in "project" condition so something that might need work done to it but not something that has gone to far with rust! I dont mind Rust aslong as its not to extensive or hidden by bog (the worst type).
HR31 - coupe
DR30 - coupe (mabey sedan)
C210/11 - coupe or sedan
240K - coupe or sedan
And although not a Skyline a later model 260C (ones with "notched" rear doors)
Current offer is $2500 max but this is subjected to change and will be update accordingly, I do understand the rarity but then again im not looking for something in show room or original condition im just chasing a good, honest base for a project.
thanks!
ipb.global.registerReputation( 'rep_post_6456899', { domLikeStripId: 'like_post_6456899', app: 'forums', type: 'pid', typeid: '6456899' }, parseInt('') );
For that money there are some lovely 240/260C's on ebay at the moment well within budget. 240ks are going for crazy money - far more than $2,500 for a project. C210/c211 are hard to find, but not crazily priced if you get lucky.
I don't know about the modern stuff you mention.
Ahh yeah, you need to have more posts, woops
Car: HR31 Coupe 1987 gts-x
Condition: Car near complete, less engine. Needs paint and minor body work, no rust.
Description: Car is complied, no rego. 5 speed, R200 LSD, windcreen near new
Contact Details: PM contact details, can email pics
Asking Price: $2000 $1800
Pick-up/Postage Arrangements: Pick up
Other Comments: Would make ideal race/drift car or to transfer parts off Aus skyline to upgrade to a coupe. No front seats or front calipers, still has import front struts
Moving house, would like to see it gone
Just seen the owner lists as being in SE Melbourne... that could be a problem.... Considering last year i had to give up on a 260z because i could get it from Mackay to Roma QLD (were i live).
hmm bummer! got excited to!
If you include shipping from Vic etc, with a $2500 budget that doesn't leave a lot of car! You really get punished for shipping non-drivers, as you need a flatbed rather than a car carrier.
Ceva logistics were the best I dealt with from memory.
Well yea shipping cost and well i would like to see it with my own eyes before i had over cash... Especially after I bought a VJ valiant ute with the discription of being only a few rust whole,vwas a 15hr trip up and back with a shitty trailer only to find the next day it had a half inch and in some spots a inch thick shell of bog with alot of bad structral (?) rust...
Paid $1600 re-sold it for $750 3 weeks later, couldnt stand looking at it... So I'm really iffy with older cars now.
  • 1 year later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
