Boss kit to match Toyota not sure what it
Fits exactly $40 brought brand new hardly used
In box k&n filter average condition $20
Fibre glass bonnet for a31 pretty badly damaged and genuine ceff hood liner damaged as
Well$50
Cefiro spoiler unsure if it's genuine or after market $100
Super x cannon $50
Will
Look at doing trades
Ono on all objects it's all just shit I have Lieing round at home and
Rents are
Sick of it spin us a
Text
For
Info or
Pictures
0421250737
Pick up Only
https://www.sau.com.au/forums/topic/405840-random-bits-and-pieces/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
