hi throwing up a heap of stuff ive had laying about taking up room
im located near byron bay in northern nsw
i can be contacted via text on
0447366637 -will
rb25 turbo -$200
rb25 series 1 ecu -$100
rb20 ecu -$100
s13 headights both sides no broken mounts -$200
rb turbo manifold $50
s14 gear surround -$50
rb20/rb25 series 1 afm -$70
wrx afm -$100
rb20/rb25 series 1 coil pack loom -$30
rb20/rb25 series 1 coilpacks -$100
rb25 series 1 ignighter -$50
r32 gtr radiator -$100
small front mount 450x300x75 -$100
s13 sr fan shroud -$50
s14 sr fan shroud -$50
rb20 non hicas power steering pump -$50
180 sr back seats -$80
rb20 3inch split dump front pipe -$150
s13 sr 5 speed good condition -$400
s14 sr used exceddy clutch and flywheel and bolts -$200
s14 NA sr dizzy -$50
VCT sr intake plenum -$50
VCT sr alternator -$50
VCT srstarter motor -$50
S14 seat belts and buckles -$150 all 4
S14 brake booster -$50
180sx rear plastics -$100
S13 front gaurds average condition -$80 pair
s13 ultra fender braces -$150
180sx wanga wing -$150
180sx bn kit brand new -$700
180sx 30mm rear gaurds-$150
180sx stock rear bar -$100
s13 aero plastic skirts good condition -$200
180sx ca front bar with indicators cut up a little -$100
wrx front and rear seats -$400 whole set
wrx gauge cluster -$100
s14 NA sr manual ecu -$100
s14 NA sr auto ecu -$100
wrx kebab spec tail lights -$200
wrx standard turbo -$100
s14 3 inch exhaust with bent canon -$100
s14 k magic side skirts 2 of one side so u have a spare -$200
s13 NA sr air box -$50
rb25 ff plenum greedy copy brand new -$300
rb25 standard injectors in rail -$100
s13 sr standard turbo and lines -$150
s13 sr standard turbo manifold -$50
https://www.sau.com.au/forums/topic/406144-180-part-out/
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
