Justin's Pie Cruise! Sept 16Th Robertson Pie Shop!
  • Replies 98
Posted Images
Guys, This date is pending on weather, Went and did this run again last night and it was raining, it was an absolute waste of time... So if its raining we will post pone.
Really? Are you that much of a pansy you won't drive in the rain, or is it just that your car leaks/lacks a roof?
I'd only avoid Mac Pass in extremely extremely cold weather (Like we had last friday) and it's raining, this equals snow + black ice.
Oh and in a raging thunderstorm that you really shouldn't be leaving your house because of, as it'll bring branches down.
I'm not a Pussy, I'd just rather post pone it so that Everyone can enjoy each others cars, in the nice sun like we normally get when we go up there as a club, But if this recent weather reflects on what it's going to be! All lights are green!
leave time 10 A.M or is that to early for everyone?
Hey, I'll be coming as well. Can you give me a little summary of this thread? So far I've picked up: Meet at Casula KFC @ 10AM, Sunday 16th.
Meet Car Park 9:15 Am Onwards, DRIVERS BRIEFING AT 9:45 AM! 10AM SHARP DEPARTURE TO ROBERTSON PIE SHOP VIA, HUME HIGHWAY-PICTON ROAD- MT KEIRA PASS- EXPRESSWAY TO ALBION PARK SCHOOL - MAQAURIE PASS- PIE SHOP- EITHER GO HOME OR DO JAMBEROO PASS.
Bring, Fuel, Safe Driving, freinds, Camera.. Money for Pies and other foods once we arrive. Follow the White R33 (Mine) And the Purple GTR (Owen) We Will Be Leading the cruise and sticking to the speed limits at all times, make it a nice cruise with each other no need for speed, just enjoy the roads and the company.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
