Recently my 25det neo engine in the 34 has decided to make a very healthy knock noise!
In the attached video clip I have 1st put a pool noodle to the timing cover which has enhanced the sound, then 2nd onto the exhaust side rocker cover which sounds like normal tappet noise, so the knocking is either coming from the belt area or worse it is resonating up through the block.
Any ideas? Big-end bearing/timing belt bearing/worse?
Cheers All.
timing cover then rocker cover.wmv
https://www.sau.com.au/forums/topic/406836-knock-knock/
Last change penrite 10's racing 10w-40 full synthetic + 1/2 qrt of lucas, before that it was motul 300v
145,000kms btw on the clock, compression is very healthy/engine is still very strong and responsive.
Hoping it is timing belt, loose/slapping/timing bearing that needs replacement, but after listening to a load of youtube vids I am thinking rod knock :angry:
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6485196
You could just replace the bearings , i mean , it won't last forever and is by no means a permanent fix , but it would get you out of trouble for Atleast 6 months (providing there is no crank or con rod damage ) . ~$50 and a good day of work for someone mechanically minded
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6485282
Yep Motul all the way from now on!
I am lucky enough to have another nice 34 to drive atm, will be looking to pull down my 26/30 proj engine that has been sitting for almost a year now and try and do all the work myself/save coin, bottom end needs a rebuild, does not look to be too hard a job once the machining has been done, and there is so much info round here I am sure I can do it with patience and learn along the way.
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6487304
Nah not at all eh JEZ, that engine is stock and so healthy across all cycls that is why I was not worried about the high kms, was looking to just put a bolton package in there as it is the weekend/cruiser, just bad luck I guess or previous history has now caught up.
Still deciding if a RIPs 30 bottom end delivered would work out better than rebuilding the current patrol 3ltr bottom end, would just need a better oil pump and be machined/bored/honed to accept forgies. RIPs stay with stock internals and do some crank work, but they are good for 600 ponies.
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6487574
  • 3 weeks later...
Right O!
I have finally located the the source of the issue, the knocking sound is the CAS arm that enters into the exhaust cam shaft area, it appears to have too much play/wobble in there and the effect is a vibration/knock sound inside the chamber, this has resulted in what so sounded like rod knock resonating from the block up!
So on to resolve the issue - replace the CAS unit (expensive as all hell from Nissan) or further diagnosis and pull off the rockers and inspect the cam shaft and barrell area? I wouldn't expect this part to be the issue/worn out as it is forged steel.
Anyone out there know if this is a common worn out part issue for a CAS unit or has come across?
Cheers All.
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6513355
Mine did the same, the damage with mine was mainly the nose of the cam, and the CAS to a lesser degree. The damage to cam is pretty obvious, if you look in the front of it the teeth should be square, and 1+mm across the top. Just Jap had the CAS second hand in good condition, the cam I just bought second hand off here
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6513398
I had to strip some parts from the 26/30 today and use the aluminium bracket from the 26 head gear that the CAS is mounted to , on the 34 it was fractured and only being held in place by the CAS bolts to the timing cover, now the CAS has no play whatsoever all fixed, but the knocking is now very clear and coming from the front of the exhaust cam shaft, so perhaps the same issue you had IPLEN and it has been worn away, I guess it is a pretty inexpesive exercise to swap a factory exhaust cam in there and see if the problem goes away, it should not cause any dramas if I leave it as is, but I want rid of that knock noise that is only there on idle, when on accelaration it goes away and then comes back on decel to idle, very noticeable at idle.
Check out the fractured bracket, it is just cast aluminium not very strong, and I am not sure what caused it to break just recently either!
https://www.sau.com.au/forums/topic/406836-knock-knock/#findComment-6513669
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
