S13 weld in roll cage for sale.
Made with CDS (cold drawn seamless) 350n/mm2 mild steel tube, 44.45mm main hoop and 38.1 lateral half roll bars and transverse member as per CAMS requirements. All bends are made within CAMS guidelines. Tubing has been notched at connecting points.
This kit is the perfect base to construct your own cage and save a lot of $, pretty much all other members could be manufactured out of straight tube or with a few minor bends.
This cage has been fitted to my S13 during construction to ensure a nice tight fit. As can be seen in the pics it runs flush with the roof and A -Pillar.
To fit this cage, some very minor adjustments may need to be made and you will need to make your own mounting feet. Flat plate in the rear and custom feet in the front out of minimum 3mm plate to meet CAMS specification.
If you would like more bars included or to be fitted to your vehicle, contact me to discuss.
Tac welded for photo purposes only.
Located north side of Brisbane, prefer pickup but happy to freight if you arrange.
$750.00
Cheers,
Matt
0418719626
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
    • This thread keps giving with the OMG!
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
