As above, AME Tracers 18x9.5 +22 in dark grey.
These were used as track rims, they did an airport run 2 months ago which took quite a few chips out of the paint.
So with a respray they would look perfect, for track rims though they are perfect as they are.
They are fitted with Hankook Z221's in soft compound, 265's all round. These are awesome tyres, as used for one track day. About 80%
THey will also come with Hankook Rs3's, 265's all round, used for one track day. About 80%.
The Z221's cost $1800, the RS3's cost $1200
$3000 for the lot
In sydney
Will do the lot for $2500 plus swap for cheap crap stock wheels and tyres, or any wheel/tyre combination that can fit.
Can be space savers for all i care....it's purely so i can roll the car around.
  • 3 weeks later...
  • 3 weeks later...
$2000 for the lot, will not separate.
Pickup only in sydney, bargain....sold everything else off my track car this is all that left.
Just want it gone
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
