[Vic] Jvc El Kameleon Cd Head Unit, Top Of The Range. Can Post Australia Wide
The KD-LX30 is JVC's new high performance El Kameleon II anti-theft CD Receiver with CD Changer Control. This a very unique, top of the line head unit and people that know about stereos will know this
It features dual gold 4V pre-amp outputs, a sub-woofer output w/ crossover, and an adjustable auxiliary input. Other standard features include a 45 Watt X Four Channel amp, BBE II Sound and JVC's best HS-II tuner. Added convenience is provided with a card-type remote, Audio Cruise mode and CD Text capability.
45 W x 4 Max. Power Output
CD Text for CD Player and Changer
1-bit DAC
CD Changer modes:2 Random Play, 2 Repeat Play and 2 Intro Scan modes
CD Player Intro Scan
Direct Disc Select (1-12)
CD Player Random and Repeat Play modes
HS-II Tuner. European Switchable Tuner.
18FM+6AM Presets
SSM (for FM)
AFNS/PNC
Display: Volume Meter, , Switchable Dimmer
Card-Type Remote
Sound Control Memory
COMPU PLAY
Beep Tone Support, Rotary Encoder, Power-Off Eject, Preferred Setting Mode, Power Antenna Lead
Direct Track Access (1-12)
BBE High Definition Sound
Electronic Volume Control
Audio Cruise Mode, Bass/Treble/Balance Controls, Volume Attenuator
4 Line Level Outputs (V)
Line Out Terminals (2 pair/gold)
Preamp Fader Control
Here is youtube video on the head unit, so you can see some of the functions
The unit is in very good condition, The sound Quality will blow you away,
it is missing the remote which is cheap like about $20 to buy.
Asking $200 for the unit, No time wasters please.
This unit has a RRP of $799
Pick up is from Glenroy - Melbourne. Can post Australia wide for an extra $15.
Call or sms me if interested on 0422756270
Screen goes completely black when you turn it off for security
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
