Hi Guys,
I was tired of fingerprints all over my b-pillar so I decided to get a set of these CF vinyl overlays for the B-pillar from Ebay.
Applying was easy. Came in 6 parts and were all pre-cut to spec for the sedan. The rear bit could have been 1-2mm slightly wider but overall looks good and best of all no more finger prints!
If anyone is interested here's the link from Ebay US. Took exactly 10 days to arrive including weekends. Pics below.
http://www.ebay.com.au/itm/03-06-Infiniti-G35-CARBON-FIBER-B-Pillar-door-covers-35-window-trim-fibre-cf-b-c-/230690789595?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b63e18db#ht_2056wt_1304
https://www.sau.com.au/forums/topic/408983-cf-b-pillar-overlay/
That looks awesome! I was just thinking of getting the same thing except rather than vinyl, I'm getting these once i paint my window trim black
http://www.ebay.com.au/itm/Infiniti-G35-03-06-Prestige-Real-Carbon-Fiber-Door-Pillar-B-Pillar-Parts-Post-/160870580218?pt=Motors_Car_Truck_Parts_Accessories&hash=item2574a23ffa
Thanks looking forward to see what you do to your ride
come in my thread check it out. My comment by no means is an offence ^^, jst personal ^^...btw, looks like ur quite experienced wif V35, mayb you could help me answer few questions in my thread. cheers :)http://www.skylinesaustralia.com/forums/topic/409335-self-intro-any-help-would-be-much-appreciated/
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
