Red top SR20DET Long motor 100,000kms, with Loom $1200 (excluding turbo, injectors)
Have a vid of engine running and have had a compression test done
S13 Redtop ecu with Nistune $350
Garret GT3071R Turbo, .86 rear housing, 52 trim, Mint cond no shaft play $950
SARD 550cc injectors $400
SARD adjustable fuel pressure regulator, with earls fittings and adaptor $160
GENUINE Z32 Air Flow Meter $150 (no plug)
Walbro 255L/H Fuel pump $100
Can do all of the above as a full package ready to drop in for $3000, good for 240 – 250rwkw
3inch one piece dump and front pipe with O2 sensor $120
3inch stainless Fuitsubo exhaust with hi flow muffler and gutted cat $250
Turbosmart 38mm sleeper series dual port blow off valve $250
Greddy Profec B spec II Boost controller $300 ( pretty much brand new )
NEW Pod filter $50
Greddy catch can $50
DRIVELINE
Tomei 2 way diff in housing Housing ( 5 bolt ), 4.11 ratio $750
S13 gearbox 100,000kms $600
S13 manual tail shaft with centre bearing $100
S13 clutch master cylinder with slave and lines
S13 manual pedal box
Can do a deal for a full manual conversion minus clutch and flywheel
C's short shifter - $150
EXTERIOR
ORIGIN Roof spoiler $180
Crystal JDM tail lights $150
complete S13 Silvia doors – paint and trim in mint condition $120 each or both for $200
S13 boot lid, spoiler holes welded and has been re-painted mint $100
S13 rear stock bar with reo Mint $100
Windscreen good condition - $100
Rear window $100
16x8 genuine R32 GT-R alloys - $500
INTERIOR
S15 Rear seat complete $100
S13 Rear seats $20
Greddy GREX Gear knob $50
Black suede dished steering wheel $100
Bride Fixed back bucket, with drivers side rail (side mount)$400
Black Dash Mat $60
S13 dash mint condition no cracks or fading $200
S13 digital climate control with loom $100
SUSPENSION
Unkown rear strut brace $50
Tein HE coilovers front and rear with camber tops $750
Silk Road adjustable castor rods with rose jointed ends $100
5stud conversion with brakes
5 stud front hubs and bearings pressed onto S13 knuckles and uprights
R33 rear twin piston callipers(bendix Pads) with 5 stud hubs and drum brake set up
R32 BM44 brake master cylinder
R33 handbrake cable with adaptor plate
S15 front callipers with Bendix Ultimate pads, and RDA rotors
Total brake set up package: $700
S13 shell with damage! Has Walk in S,A Rego! (rego is for SR20DET) $800
all parts located in Adelaide, will post most items at extra cost
will have pictures up soon, can email/txt pics for now though
cheers
Can I get pics of these?
Cheers
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
