Selling my 19 inch Lenso rims with Pace tires (235/35/R19 -- tread on 2 wheels are pretty worn and the other 2 are of decent tread).
They are 4 stud and will fit directly with no modification to any r33 GTS NA.
They are in a brilliant condition with not one sign of gutter rash or paint chipping !
Bought these last year from Tempe Tyres for $1700 and I am willing to let these go for .....
$1200 negotiable !! throw me an offer, cash prefered.
Contact me via PM or for a quick reply text or call me on 0420 711 211 for any details.
Will NOT post, only pick ups in SYDNEY.
Edited by Mitz
bump
Edit -- Pictures disappeared for some reason and i cant edit the original post. So if anyone wants a picture, text me on 0420711211 and ill send them to you
cheers
Edited by Mitz
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
