dont know if id really trust my 15yr old airbag......Can these things be tested? would be good to know since its there anyway
He has a point, at what age do these things become disfunctional? or worse actually dangerous?
Give it another ten years and I could imagine a explosive device after 25 years being a issue.
Having issues with trying to find hicas boss kits.
14 seconds on ebay. Even found it with the type of steering wheel ur after..
http://www.ebay.com.au/itm/Deep-Dish-Drift-Steering-Wheel-Boss-Kit-Nissan-Skyline-R33-S14-200SX-Hicas-/130773826050?pt=AU_Car_Parts_Accessories&hash=item1e72ba3a02
skank pink!! sold.
no one has answered me yet, can i reverse it all and put the std one back on after without error code issues, or would i have to visit a tuner to clear the computer.
Just in case i have to put it back to standard one day.
skank pink!! sold.
of coourse you could put it back to standard.
N computer issues etc would have been discussed somewhere. Do a search n see if that offers any suggestions.
Edited by jjman
thanks ,thats the answer i needed.
wheel and boss brought.
this resistor sold on ebay goes onto the ecu board? or soldered on the back of the dash?
resistor? not heard of that before but if i can offer any advice- dont be f**king around with circuit boards n soldering- much less of the ecu. these are old vehicles and alot of these old components are easy to damage...
honestly, id just unplug the globe for the airbags in the dash (n convert the rest to awesome looking LED's at the same time) n be done with it. If you ever put the airbag wheel back in then put the globe back in.
Dont worry about the error code as either easily explainable- "i put in a sik pimp-red deep dish wheel for a while n now the stock airbag wheel is back in"
or easy enough to wipe error codes.
FTW
Edited by jjman
No offense, but airbags & abs are god sent. Why on earth would you disable it?
And yes, Airbag module will throw a fault code and yes your passenger airbag will not deploy.
not sure about OP's case but stock steering wheel for me meant i couldnt see any of the dash gauges, also i think that if i had an accident that wheel would have broken both my legs (i think im a bit bigger than ur average jap that this car was designed for...)
otherwise i dont see any mention of disabling ABS here.
Nonetheless, after all these years of age skylines have its just another thing that could develop a fault.
I threw the ABS thing to complete the sentence, you often see plenty of people removing their ABS systems and Airbags for more "street credit".
yeah i hear you on that.
kinda like the superstretched tyres on rims sticking out to hell + dumped to ground n wheel alignment all over the shop...
for the street ABS is ur best friend. For track or driving purists then ABS is not such a good aquaintance...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
