I have recently just done the research on these.
40030-33P07 - Small Bearing
40210-33P02 - Big Bearing
40041-33P03 - Grease Cap
40579-33P01 - Seal
I'm planning on getting the parts though www.amayama.com. Have no experience with them yet but seems like the cheapest place to source OEM Nissan bearing and other spare parts. That seal is not available through them (at least at the moment) though so for the lulz I priced it up at my local Nissan spare parts place. For reference, Amayama want about $20 per seal, Nissan wanted about $120 per seal. What a joke.
How come you are replacing them? So far I got all of mine out fairly easy except for the outer piece of the bigger bearing. I think I'll need a bearing puller for that.
Where were you planning on getting your bearings?
Need any other help just let me know, or if you have something I don't know then let me know. :)
Cheers
I am doing these on my 32 aswell at the moment. But instead of getting them through amayama, i went down to the local bearing store and matched everything up. Set me back $50 each side approx. You don't need to replace the dust cap though unless you damage it when pulling it apart.
Will post up part numbers when i finish work tonight
Yeah I just realised that too.
I can't find the part number for the bigger bearing?!
I have the top smaller bearing which is common in the HCR32/BNR32 but the lower bearing, the larger one I can only find the part number for BNR32 and I need the number for HCR32 if you guys have it?
