180sx Type X with sunroof for sale. The car overall is in good condition with no mechanical problems at all. Been running stock boost since I owned. The car has the complete Type X kit with front lip, rear pods, carbon fiber centre garnish etc. Major service has all been done so there is no need to do anything(Timing chain, diff/gearbox oil etc). The car is serviced every 5000km and spark plugs changed every 10000km.
Mods:
X force dump and front pipe.
Nismo Exhuast
5 Studs conversion from r33 skyline with Z32 BMC
Braided turbo and brakes lines.
HDI dual stage boost controller.
Saber Oil temp, water temp and shadow boost gague
Clarion Head unit.
Adjustable Castor.
Whiteline sway bar.
Sparco Wheels F17x8 +32 235/45/17 80% Tread R 17x9 +38 (20mm spacers so +18) 255/40/17 4-% Tread
Tein super street coilovers
Juran front strut brace
Brand New sunroof seal just installed
The bad:
AAC valve need to be replaced) Already bought one with new gasket arriving from japan soon.
Front has cracked paint due to some one reversing into my car and did a runner and paint coming off the rear spoiler.
Fan shroud broken by old owner.
A/C will need a regas.
Price: $11500 ONO rego till 14/12/12
Contact: 0422106112
Also interested in a swap a honda accord euro or integra type r with equal value (MANUAL) as I don't have money to put on top. Other than that, I am negotiable on the price but don't low ball me. No test pilots genuine offers only please.
https://www.sau.com.au/forums/topic/410850-nissan-180sx-type-x/
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
