It all depends on what you think is important. R33s have electric HICAS, so there is no extra bullshit equipment (hydraulic solenoids and lines) to get rid of like there is on R32s. So the minimal approach of just fitting a bar on an R33 is enough to get rid of the part that you really really want to get rid of.
The problems are that;
  1. If you leave the tie rods and tie rod ends in place then you are leaving half the places where slop in the HICAS system happens. This is compulsory if you just fit a bar.
  2. Lockbars are not road legal. They are considered to be "modification of a steering system" and unless yours is signed off by an engineer it is defectable.
There are better locking systems that include collars to get rid of slop. There are better ones that do not use a bar at all, but bolt on extra brackets and replace the tie rods and ends with toe control arms akin to what you have on a non-HICAS subframe. This is what I would fit if I was going to just fit stuff on. But what I actually did to my R32 was replace the rear subframe with a non-HICAS one, pull out all the hydraulic crap. The rear of the car looks 100% factory, so even though I have "modified steering system" it doesn't look like it, so I will not likely get defected for it even with the most Nazi cop/inspector. My way cost a lot of money though, because I had to buy the subframe and having the whole back end of the car apart was seen as an opportunity to rebush EVERYTHING.
cheers
https://www.sau.com.au/forums/topic/410958-hicas-lockout/#findComment-6575434
GTSBoy nailed it, do it properly, too much slop in the ball joints.
Get a non-HICAS subframe from an S14, replace the balls joints in the knuckles with bushes (SuperPro SPF1638K) and run adjustable toe arms.
Edited by Akshunhiro
https://www.sau.com.au/forums/topic/410958-hicas-lockout/#findComment-6576547
cheers
hi mate thnx for the info only thing is on my island we dont have any laws limiting what mods we can do to the cars we run every single mod there is we run on the streets becuase the cops dnt even check and cant say anuthing because there aint no law against car mods in a short way to say everything is road legal here
how about if i trow a bar and get other tie rods and tie rod ends???
because to get parts down here is a pain in the ass!!
https://www.sau.com.au/forums/topic/410958-hicas-lockout/#findComment-6576671
Hey, I didn't see you were in the Carib. Cool.
Of course you can buy new tie rod ends (don't need to replace the rods themselves), but it's not worth it. If you're going to buy new rod ends, you might as well buy stuff to get rid of the rod ends. Something like this http://www.nengun.com/midori-seibi/hicas-canceller or this http://www.nengun.com/nagisa-auto/hicas-cancel-rod are smarter.
https://www.sau.com.au/forums/topic/410958-hicas-lockout/#findComment-6576748
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
