Genuine WALBRO 460LPH E85 Fuel Pump
- Most popular in-tank performance fuel pump on the market today
- 460LPH flow rate + E85 compatible (purpose built)
- Standard 38mm fuel pump design
- Can support upto 950HP at 13.5 Volts
- Genuine WALBRO – manufactured in USA by TI Automotive
- Comes with 2x strainers and everything pictured - OEM # F90000267
++ Comes with a free Delphi wiring harness (male plug) ++
$295 $235 incl. Express Delivery << SAU Special
* This is an Australian delivered product with a national warranty.
  • 5 weeks later...
  • Replies 59
how much will this support power wise ?
Hi,
It's designed for engines exceeding 500HP as quoted by Walbro.
- Brendan
im also keen to know about this?
I've had a look on there website and there is no technical specifications of the sort on there.
I would say google it.
ok so how can you sell it as a purpose built E85 fuel pump if you cant answer as to why?
This is a Walbro fuel pump that is intended for use with E85 fuel, I am not aware of the exact reasons that make it E85 compatible. You are welcome to contact Walbro for technical enquiries of this sort.
  • 2 months later...
Received mine today, awesome price and super fast delivery !!
Thanks
Lol we should probably bump the price up on these :D
Enjoy the pump!
Do you have the male ends of the plugs with these or is it a standard Bosch type plug?
Hey,
It's just the standard plug as pictured above, you can get the male ends online as well.
- Brendan
are these universal kits? or model specific. got anything for a evo ct9a?
Hi,
Na just universal comes with 2x strainers and everything you see in the image.
Nothing specific for the EVO's yet.
- Brendan
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
