I bought the car as a shell and built it from there. Huge list of modifications do not want to know price to build car 95% of all parts purchased brand new. This car drives amazingly and is a complete animal, not to mention has the looks to match. You will notice in the pictures the unfinished front guards. This is due to not having wheel lips for my 18" equips, so i never got around to completing a set. Some aggressive FRP guards could be bolted on to set it right off ! Car is always looked after / garaged and serviced only with Mobil products. Also gets plenty of attention at the track =P
I too have no problem sending this interstate I've used a very good company before bringing a car up from VIC.
Price = $22000
Engine - Build Buy KJ Motor Machining, Kohen builds drag racing engines to blueprint with extreme tolerances, the motor cost a f**ktonne.
The car had no Odo, but it wouldn't even be close to 5000km, gearbox was rebuilt at same time as motor. It was also built for 30psi roughly 600HP.
Mahl pistons
Scat rods w arp fasteners
Mls headgasket
Acl mains
Arp big end fasteners
Arp head fasteners
Arp main fasteners
Ati balancer
Supertech valve springs
Re-welsh plugged
Tourqe plate honed to .20thou
Oil galleries drilled larger / tapped
Valve seats re-cut / valves faced
Crank collar welded / machined / re-ground
Block n Head re-faced
Balanced, Rotated n blueprinted.
Head ported / knife edged
Garrett Gt3076 .8 (rebuild by garrett when engine was built)
Hks 264 9mm cams non-vct
6boost forward highmount - head wrapped
Turbosmart 38mm Wastegate
Freddy plennum faced and port matched
Decs 550cc inj
Q45 TB
Carbon Fiber Cam cover & plug cover
Nismo FPR
Mezier waterpump (controlled by haltech to act as thermostat)
NPC lighten flywheel n 5 puck cushion
Rebuilt 25box
PWR xflow GTR radiator
PWR custom Intercooler
PWR oilcooler w. Enzed Lines
PWR powersteering cooler
Motor into firewall 1.5 Cyl
Fuel cell w. Surge & Dual Walbro pumps
1.5 to 2" screamer pipe
Full 3" Exhaust wrapped
Extreme Custom Engineering 2x4" twin tip exhaust
Suspension
PBM Coilovers 10/8
PBM LCA front / rear
PBM toe
PBM camber
PBM castor
PBM traction
PBM cradle risers
Driftworks Hubs (modified for dual caliper)
Whiteline Adjustable sway bar front / rear
Extreme Custom Engineering catch can, with drainback
Drivetrain
rb25 box (rebuilt same time as motor, new 3/4th synchro & bearings all round) by DANSTRANS
Urethane Mounts
npc lighten flywheel
5puck clutch
Quartermaster hydraulic throwout bearing
Hardy Spicer 1 piece tailshaft
Kaaz 2way
R33 Gtst Brakes w. DBA rotors w. QFM pads
Dual Calipers for separate Hydro
Electrics
Haltech PS2000
Racepak IQ3
Wideband Controller w. Sensor
Boost Control Solinoid
Oil Pressure
Oil Temperature
Water Temperature
Air Temerature
3bar Map Sensor
Haltech TPS Sensor
Standalone LS1 coilpacks with custom Eagle plug leads
MR2 Electric Power steering pump mounted in boot.
Single engine loom plug on firewall
Full rewire with a EZ kit
Switch panel's control everything
Exterior
Onevia Conversion
Tinted red taillights
Dmax type 3 kit
Dmax type bonnet vent
Dmax roof lip
Custom Metal Widebody
Painted Black
Interior
Bride ZetaIII drivers seat
PBM hydro w. Tilton master
S15 Dash
Tilton floor mount pedal box w. Tilton masters
Chassis
Fully Stitch welded, underside aswell
Rear firewall, due to fuelcell
Notched firewall for motor to sit back 1 1/2 cylinders
Framed rear end, for fuel cell
Huge front tubs
Rear Tubs w. metal widebody
Tubed front Reo, sits tight in frontbar
Wheels
Front - 18x8.5 SSR Vienna
Rear - 19x10.5 +12 Varrstoen (x4)
The work equips are not included in the price but could be negotiated.
Power
450rwhp @ 17psi tuned by Chris @ Bob Romano's
Spares
2 x 5bolt drive shaft
4:1 Diff gears w. housing
2 x Tilton master cylinders
Tilton Remote brake bias adjuster
Steering Rack
Whatever else i can find for it
Pictures
I'm sure there is allot I've forgotten i can be reached on 0420 855 181 if you have any questions or want to check it out. I will continue to drive this at the track until sold.
I've f**ked up the price its $19,500 with the SSR Viennas / Varstoens.
$22,000 with the equips (18x9.5 front 19x10 rear) there not shown in the photo, will have updated pics soon.
chrome equips 19x10 19x11 are $2800 extra
great build.... very impressive sad that u want to sell her.... off topic i know but did the stiching the rear make a difference ?
whole things stitched, only time u no the difference is when you jack one corner it goes up level and u can balance wheels opposite corners on curbs, not that i can get this out my driveway =[
would make an awesome car for competition, hopefully have some decent pictures up within a few weeks, got a bloke wanting to shoot it =P
This is the hottest car i have seen on this forum. id buy it for 22 tomorrow!
and you haven't contacted me why? haha
if your actually serious and not just slinging jokes call me 0420 855 181
peace
sorry maybe i shouldve worded that better. id pay 22k for that tomorrow as in, i think its worth that and if i had 22k id come and buy it, congrats on building such an epic car, but i dont have 22k to come down and get it!
bump, can do an extreme package
car + 8 work equips + 4 varstoens + dual axle trailer (tyre rack, elec winch, toolbox) = $29,000
will include every Nissan part and car related parts i own.
  • 1 month later...
  • anyone wanna swap a basic s13 or s14 + cash?
  • something along the lines of Sr manual, t28bb, coil overs, 2way, castor / camber / toe arms
  • 1 month later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
