lol... I'm sure we could work something out location wise if you where willing to come here.... and the price is negotiable, so if you're genuinely interested, make an offer and see what happens... :)
But yeah, It's very clean, my car's are my pride and joy so I make sure i look after them...
Thanks man.
Dave.
Also, I forgot to mention it's a manual, and if there's anything else I've forgotten please just ask...
Hey guys, I have had a lot of interest so far but the car is still for sale... Also, I think i forgot to mention that it's a 5 SPeed manual, a couple of people have asked.
I also have all receipts for everything that's been spent on the car too...
Cheers,
Dave.
Hey mate,
So sorry i took so long to reply, YES, still for sale.
Interior is beautiful! (and i mean that honestly), no not a Type M as far as i know.
Cheers,
I've PM'd you my number incase you wanna discuss details.
Dave.
