Selling my stagea.
7XXXX kms
ACT rego
Trust FMIC
E-boost 2
Power fc
Exhaust system
Tomei Cams with adjustable cam gears
18inch apexi rims
$22,000 ono
I'm interested in getting another r33 gtst with at least 250kws so might be interested in swaps plus cash my way
https://www.sau.com.au/forums/topic/413070-1998-nissan-stagea-rs260-autech/
thats not even funny sin! well it weill be at the sau day on the friday then ill be with anfanee getting kms up on his car
Speaking of... i applied to take the friday off as well.... so we can take my GTR all 3 days if you like. Unless you want the stagea to go mate.
Maybe take it up on the Sunday and enter show n shine with an FS on it ??
That is a good idea sin! Nick. go.
  • 1 month later...
  • 3 months later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
