Hi all,
Thinking of selling off my civic as I'm looking to buy a GTT, will use it for daily to replace civic hence getting rid of it. Just wondering if anyone is interested in buying this? It's stock standard (i have only changed the headlights + interior dome light), in fairly good nick though there are a few scratches here and there, very minor you'd have to be looking to see them. Car runs very well, obviously never thrashed (is that even possible?) safe and great daily drive.
PM me for more details and if you want more pictures and/or to talk about prices.
Located in Sydney, NSW.
https://www.sau.com.au/forums/topic/413785-nsw-eoi-civic-gli-1999-champagne/
bump, PM me for my mobile if you wish to enquire more (or just PM me your enquries)
Has 129XXXkm on it - 13y/o car so you can see that it's pretty low for an old daily!
Edited by darksky34
Ok. Thought I didn't really need to since it's just an EOI - but no problems.
Looking for $5500, but definitely willing to negotiate as there are a few things which may need fixing:
- both rear windows don't wind down well/at all but will go up fine (electric)
- some kind of belt/fan noise will get that checked out soon
- there is a scratch on the windscreen but literally unnoticeable
Basically nothing which affects the running of the car (apart from the belt/fan thingy which I will get fixed soon), so it's a great daily. Hit me up with offers.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
