Ok, I did a quick search but couldn't find any info I'm chasing.
Originally ordered some whiteline F+R swaybars for the HR31, after a few weeks we were told they aren't making them anymore due to lack of sales, as this car is being setup primarily for track work, I'd rather have some thicker ones in there.
Is there anywhere else I can source some for it?
Appreciate any help.
https://www.sau.com.au/forums/topic/413829-hr31-swaybars/
I can do a little research on the Whiteline front if you like; but I had bars custom made by Todd Selby a couple of years ago to my requirements, and he was excellent.
PM if you want some more assistance.
https://www.sau.com.au/forums/topic/413829-hr31-swaybars/#findComment-6630463
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
