kms: 145 xxx
Price : $12,700
Selling my R33 as iv decided to put an end to the import game and it never gets driven due to using my work ute 247. The car is in great condition for its age , iv looked after it to the best i could possibly can. Always serviced regularly every 5000 kms . The car has probably only seen about 2,000 kms in the last year , as its only been a weekend car . Iv spent at least 10 grand on this car during this year , all mods are more than new .
Mods include :
- Kouki Headlights , with 6000k HIDs (Clear and clean)
- Full 3 inch Trust Exhaust
- Leatherette Seat covers front and back , black with red stitch
- Lenso D1r 18 x 10 +22 all around (new only done 1000 ks on them , tyres have heaps of tread , no rash at all)
- Greddy copy plenum
- Aftermarket Radiator
- High flow K and N filter
- 7 inch screen with Blue tooth , gps , tv , etc
- Jaycar Kevlar speakers , 2 amps and sub .
- FMIC
- Manual boost controller set at 10 psi
- Explosive bodykit
- Custom Gauges , ex temp , water , air fuel
- Hks Lowered springs
- Pumped Gaurds
No major scratches , few small dents here and there but its a 16 year old car so all in all i wont put up with clowns coming out trying to carry on about silly things , its not a new car , but as mentioned i try look after it as best . Always turns heads when shes on the road . No accident history , not on revs etc. Looks and sounds tough , all in all she just needs a tune , but at this juncture im done spending money on cars . Never been defected for anything . Any more pics just ask , i will get some more of the seats if needed. Pm me if you have interest , no swaps or anything like that , just pure sale .
Cheers
Edited by sky017
https://www.sau.com.au/forums/topic/414387-r33-series-2-black-sydney/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
