Item: R32 Cusco D1 6 point full cage including side intrusions. Resprayed in Cusco blue(except for 1 bar too show authenticity)
Cond: Excellent, couple of scratches on side intrusions.
Reason for sale: Going weld in.
Price: $1000ono, will ship...
PICS: ALSO HAVE MANY PICS ON MY PHONE, MSG ME FOR MORE.
Item: whiteline 24mm adjustable R32 gtst front sway bar
Cond: good, perfect working order.
Reason for sale: not needed
Price: $200 ono
Item: r32 gtst turbo injectors
Cond: good, working order.
Price: $50
Item: Blitz Pod Filter
Cond: couple of small holes, nothing major, still works well.
Reason: air box
price: $15
Item:R32, a31, r33, r34 Bride side mount seat rail.
Cond: perfect.
Price: $220
Item: Nardi classic 360mm flat
Cond: Excellent, small abrasion as seen(looks worse in pic), no horn button($15 on ebay)
Price:$150
Item: Blitz R-Fit piggy back ecu (same as an safc)
Cond: brand new in box
Price: $250 (rrp is $350 on this and its brand new)
Everything is located in Melbourne, inner eastern suburbs.
PLEASE MSG ME ON MY MOBILE 0407 056 817!!!! DONT PM ME AS I DONT COME ON HERE OFTEN. THANKS.
Edited by Jack_Sky
  • 4 weeks later...
BUMP!!! NEED THIS STUFF GONE GUYS!
cage $850!!!!
sway bar $150
bride rail $200
piggy back ecu $250
BUY BUY BUY! also have heaps of r33 parts im wrecking, see my topics.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
