hi guys,
i got aftermarket shocks and they don't fit the OEM strut mount holes as the threaded area is approx 2-3mm larger than OEM.
is it possible to enlarge the centre area so they can fit?
the metal sleeve seems to be one piece with the rubber mount so i am not sure if it can be removed and just run a smaller shim? i guess drilling would be easier.
circled in red, picture used as an example.
any help much appreciated.
Cheers!
In my experience that metal sleeve ISN'T attached to the rubber. Just use some silicone spray and knock it out. You can swap for a thinner shim, or get it machined.
I had to do the opposite and make it tighter. I just used some silicone wrap to fill the gap.
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
    • Nice, that's not laggy swtching between functions at all. Could it be less laggy than the factory one below? 😋
