Im thinking of getting these ASNU1000cc injectors, do any tuners or people that have these on their cars.?Im after knowing if they do improve economy with the30 degree 7 hole spray pattern. The science behind their product is good. if theyre marketing is true they wont be any issues with them.
http://www.asnuperformance.com.au/gallery/High%2BPerformance%2BInjectors/ansu-performance-1000cc-injector/110282.
https://www.sau.com.au/forums/topic/415342-asnu1000cc/
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
