Toyota Chaser JZX110, pearl white, immaculate car, 1JZ engine, Enkie RP01's with semi slicks!!
Detailed Comments
Up for sale is my Toyota JZX110 Mark II G-tb Car has traveled a mere 65565kms and is used as a daily ride. There have been minimal modifications done to this car and it has had an easy life. Car is kept undercover and well maintained. I get 450-500kms per tank of BP98 around town. Just serviced with fresh oil/filter and Toyota genuine Long Life Coolant. Automatic Sunroof HID headlamps cars' Rear privacy screen Factory tint Lower/stiffer suspension (Fortuna spec) Enkie RP01' mag wheels and body kit - Styled by Modellista 6 stacker cd player All factory books included All import papers included Electric drivers seat Toyota premium horns Fog lamps/turning lights Genuine Mark II sill protectors Optional hand grab in boot for easy close 2 keys (new battery installed in main key) spare tyre Standard tool kit included Genuine Toyota Mark II 5 piece floor mat set All inspections welcome, feel free to call anytime
Please make realistic offers and hit me up with swaps :)
0431388718
$15,990.00
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
