I went and bought a remote start alarm for the staes a month ago wanting to put it in to my Skyline. When i rang up insurance they said they require an Austrailian standards alarm so i have no use for it!
It has remote start
cold start
Built in turbo timer
Paging
Shock detection
LCD remote etc...
For any more info PM me or email [email protected]
It is a very nice looking system and as i said had all intentions of putting it on my car but can't.
PRICE - $300 ono
Want to sell quickly
Also have a set of blue FOX motorbike gloves that i want to get rid of.
They are size 8 and in good condition.
Price $25 firm
This is what i found on the internet about it...
Deluxe Two-Way Remote Car Starter - Air WolfTM Deluxe
Summary: Remotely start your car from the comfort of your home or office using our
portable 2-Way Handheld Transceiver which comes with an LCD display
How It Works: Air WolfTM Deluxe Remote Car Starter lets you start your car and turn
on its heater/defroster or air conditioner from the comfort of your home or office,
up to 1,000 feet away
FEATURES
Two-way communication between your vehicle and the handheld transceiver gives you
real-time status of your vehicle. You will know immediately when your vehicle is
started, when the alarm is triggered, when the lights are left on, etc . . .
Remote start with up to 1,000 feet of range
Lock/unlock doors and pop trunk
SofGlowTM backlit LCD screen for night visibility
User selectable engine run time, timed start, and turbo timer
Headlight or parking light activation (selected during installation)
Headlight reminder - warns you by remote if you leave your lights on
CarFinder® - Locate your vehicle easily
Real-time clock with parking meter and run times
Tamper report when disarming system
HAND-HELD TRANSCEIVER SPECIFICATIONS
Battery life: up to 6 months on 1 AAA alkaline
Low battery indicator
Displays current time (Memory is held for 1 minute while changing battery)
Displays time from when you last left the vehicle (i.e. parking meter time)
Displays run time while under remote control
Signal strength meter is great for finding your car in a parking lot
LCD display shows each of 6 zones for alarm activation
All vehicle features adjustable by menu on hand-held transceiver:
Valet Mode - On or Off
Configure Siren - Off or 1 to 25 seconds
Configure Cold Start - Wait between starts - 1 to 12 hours
Configure Engine Run Time - 1 to 25 minutes
Configure Clock Time for Vehicle to Start
Configure Turbo Features - 1 to 20 minute cool down
Configure Automatic Door Lock - On or Off
Configure Auxiliary Output 1 or 2 - Momentary (0.1 to 9.9 secs) or latching
Leather transceiver case included
VEHICLE CAR STARTER MODULE SPECIFICATIONS
30 amp relays on board for START, IGNITION 1, and ACCESSORIES
10 amp relays on board for LIGHTS and TRUNK
Transistor output for IGNITION 2 (but relay and harness included for external mount)
Transistor outputs for DOME LIGHT, AUX 1, AUX 2, DISARM, REARM, and STARTER INTERRUPT
3 Amp power transistor output for SIREN
Positive and Negative power transistor outputs for LOCK and UNLOCK
Works with both automatic transmission and manual transmission vehicles.
Full alarm capabilities - Tamper report on hand-held transceiver
System comes with:
Dash Mount LED
Hood Pin Switch
Valet Switch
Glass-Mount Antenna
All harnesses
30 Amp Relay and Harness for second ignition output
Systems can learn up to 4 hand-held transceivers (either LCD style or 1-way
transmitters)
Attatched is a picture of what the remote looks like.
cheers
i didnt tel him to send it to me now, if you read what he wrote he said he would keep me in mind if other offers fell through, that why i wrote all he has to do is send it to me and ill get the money to him
If you do not want it, please do not waste everyone's time by making comments that are obviously not thought about.
krzysiu - not everyone that owns a skyline needs an australian standards alarm for insurance reasons. And many forum members have more than one car that the alarm may be good for.
If you want to comment, make it worth everyone's time!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
