Very sad im going to have to do this.
Due to some new exciting news i must sell the GTR as it won't be ideal keeping any longer.
Will also consider swapping for the right car.
Has been Rebuilt top to bottom with high quality genuine gear,
Gtr is in very good condition, just a couple of minor touch ups which i'll have sorted shortly.
Piston Originally failed on me due to a dodgy tune! So i decided to completely rebuild the motor and change the entire setup.
Current Power
315kw ATW @ 14psi
410kw ATW @ 23psi
Some of the Major Mods:
  • Garrett T04z turbo with dual entry 1.00a/r
  • xforce single manifold
  • Full Xforce Exhaust System
  • Haltech Pro Ecu
  • 1000cc Injectors dynamics
  • Carillo Forged Pistons
  • Scat Forged Rods
  • Turbo smart Dual BOV's
  • Greddy cam Gears
  • ARP head studes
  • SplitFire Coils
  • Nismo oil/air seperator
  • Titanium tomei valve springs
  • Machined ,Blue Printed and balanced including crankshaft etc.
  • Excedy/Daiken Twin plated heavy duty clutch
  • 125mm hyrbrid drag intercooler
  • Eboost 2
  • All braided lines with Heated Covers
  • Intank High Performance Bosch Pump - Ready for e85 in the future if needed
  • Upgrade Fuel Rail
  • Nismo Oil pump (not N1)
  • N1 water pump
  • Gates timing belt
  • Genuine Carbon fibre engine covers with Candy Red.
  • Block completey painted in candy apple red from Queen street
  • Limited Edition Bronze XXR wheels with Forceum semi slick compounded tyres 245/45/17
  • Nismo 320km Dash Cluster
  • Clarion 7'' touch screen unit with bluetooth.
  • complete Soundstream sound system.
*Brand new tyres going on this Friday. (275x40x17).
+ many more items which will be reflected on the invoices aswell as dyno sheets.
All modifications were completed 2000kms ago,
***Will have more photo's within a couple of days, Limited on photo's at the moment as I'm interstate.
I do have a small build thread if you require more details in the mean time.
Located around the Ryde Area.
Contact: James 0452073044
Price$30,000
Edited by binga85
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
