MY99 Subaru WRX White Turbo
165,XXX ks on chassis
55,XXX ks on rebuilt motor
Rego til April 2013.
ENGINE MODS
  • Engine is Version 5 Sti rebuilt
  • Version 7 Injectors and fuel rail
  • Sti heads with titanium intake valves
  • VF23 Turbo
  • Hybrid Front mount intercooler
  • 3” exhaust turbo back with stock rear muffler
  • Walbro fuel pump
  • High octane racing pod box with DRFT pod filter
  • 5 spd manual with PPG gear inserts recently rebuilded ( 1-2 is helical cut and 3-4 straight cut and 5th gear stock dog ring with aftermarket shift fork) Receipts worth 6k
  • sti diffs with 4.44 ratio
  • runs ECUTEK ecu
  • Runs 19psi makes 210awkw
Exterior
  • Rear adjustable wing ( 22b adjustable style)
  • Sti fog light covers
  • Sti front lip
  • Lowered on peddars springs
  • 16” stock rims with good tyres
Interior
  • Unkown alarm system
  • ignition & fuel pump kill switch setup
  • Autometer boost gauge
  • Turbo timer
  • JVC dvd screen
  • Front and rear Eclipse speakers connected to 4 channel amp
  • 1 x 12” JBL sub connected to amp
Car starts first time every time!
Drives smooth
good on fuel
no oil leaks
Paint work is good on car it has few stone chips on the front bar
Interior is good in the car, driver seat is worn and has been stitch up abit
PLEASE DO RESEARCH ON PPG GEARBOXS, THESE GEARBOXES ARE BUILT TO LAST AND ARE VERY STRONG AND NEED TO BE DRIVEN DIFFERENTLY TO A NORMAL GEARBOX
FEW VIDEOS OF WALK AROUND OF CAR CAN BE EMAILED TO INTERSTATE BUYERS
CONTACT: Domenic 0413034521 - prefer txt or phone calls hold off on PM's
PRICE: $12500 ono
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
