Last year I did a big order on oil cooler cores, as quite a few of the RIH cars needed them.
Anywhos I've got a few left over so they are up for sale!
1. 7 Row oil cooler
use AN-10 fittings, and are made with high quality T-6061 Aluminum. Powder coated metalic blue.
oil cooler dimensions:
Overall Size: 340mm x 130mm x 50mm
Core Size: 230mm x 90mm x 50mm
Price: $100
2. 10 row oil cooler
Overall Size: 340mm x 165mm x 50mm
Core Size: 230mm x 140mm x 50mm
Price: $120
Located in Liverpool region.
Hit me up!
Adam.
https://www.sau.com.au/forums/topic/417018-nsw-brand-new-oil-cooler-cores/
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
