Part:Koni yellow height and dampner adjustable rear coilovers. not much use. came out of a dr30. fit 31 also.
Condition:good
Asking Price:$450
Part:Koni red rear shocks. 3 way height adjustable. fit r31 r30.
Condition:good
Asking Price:$90
Part:kyb excel-g rear shocks with king springs.
Condition:good
Asking Price:$60
Part:kyb rear gas-a-just shocks with cut king spring
Condition:good
Asking Price:$60
Part:hks s13 rear coilover mounts
Condition:good?
Asking Price:$20
Part:S15 front brakes (disc and calipers)
Condition:good
Asking Price:$350
Part:long champ wheels (pair)15x6.5" + 16 offset 114.3x4 pcd.
Condition:some gutter rash. tyres no good.
Asking Price:$400
Part:set of 4 enkei 16x8 + 32 offset 114.3x4 pcd
Condition:good
Description:some gutter rash and could do with some paint. 2 missing centre caps
Contact Details:Grant 0409466541. work number so sometimes cant answer. leave a msg etc ill get back to ya
Asking Price:$600
Pick-up/Postage Arrangements:pick up only
Edited by OUTATIME
https://www.sau.com.au/forums/topic/417184-sa-brakes-wheels-and-suspension/
a pair of SSR meshies 15x7" 114.3x4 pcd +11 (approx)
some gutter rash and tyres no good. $400
intercooler, core measures 300x700mm says r33 on it? $70
Edited by OUTATIME
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
