Righto guys i have for sale some old School Zeptor Mesh rims
I personally loved the look of them on my 32 GTR but have since upgraded to a set of LMGT4s as they are lighter and better suited for my track purposes. They have a good amount of dish on them as you will see from the pics and look very cool, They are also a rare and hard rim to find. Their size is 18x10 +15 offset
Condition is good, they have a spot of gutter rash on one of the rims the rest are good.
There is also a bit of grim around where the spokes join to the rim but that will clean up easy enough.
The rubber on these wheels are quite good as well
khumo 18x35x265 cant remember what model but they cost me around $240 each.. very good condition, done 3-4 thousand
the other 2 tyres are
Federals 595s in the same size, they started to get a bit of camber wear but i have had it rotated to the outside and theres now plenty of tread on the inside.. GOOD TO GO ;)
If you are a genuine buyer and are willing to actually come around and look at the rims ill be more then happy to unpack them for a proper inspections
Price: looking to get $1400 for the whole lot, i may negotiate if your not a knob and dont piss me off.. will consider offers on seperating tyres for a reasonable price
located Prestons Sydney
0432528844
Bump.. Pretty much sick off people trying to bargain me down and then not putting the money in once we have an agreement..
Im a reasonable bloke so Quit F#cking me around as my time is more valuable then the air you breathe and waste
Sold!! Good luck with the rims Rick
Also thanks Matt, one of the very few who actually called me with genuine interest..
To the time wasters and low ballers.. I hope you find a better pass time in your miserable lives
Mods please close thread
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
