1. Turbosmart Dual Port BOV kit with extra trumpets to make them completely atmospheric or have them plum back or half half or full recirculating. fitted once and removed basically brand new $250
2. Nismo Super Copper mix twin plate clutch near new 95%friction material still on it, suited for pull type BNR33, was used for about 4000 km's street use only was fitted to my 260RS $1800
3.Still way 0-400 shifter, drag racing shifter enables you to shift up gears and not mis shifting in to wrong gear. $240
4. Apexi Super Suction set with 2 z32 AMFs. $250
5. Greedy Profec B Spec2. $150
6. R34 GTR Rear Seats $200
7. R34 GTR S2 Rear Sears $350
8. R32 GTR Front Guards. they got bead blasted when my R32 was being put through restoration the guy who blasted it said oh I'm not meant to blast alloy, there are slight dents on them but can be fixed quite easily $150 for the pair
9. WGNC34 S1 Factory Front Grill with Autech sticker on it. $100
10. WGNC34 S1 260RS fiber glass front bar with vents moulded in to the bar. lower lip has slight damage to it $300
11.WGNC34 Greedy adjustable coil overs suited for 260RS not sure what the spring rates are, very firm ride no knocking or leaks.$250
12. WGNC34 S1 Manual center consol and ash tray vents and control surround $300
13. WGNC34 S2 Auto Center consol $50
14. WGNC34 260RS standard radiator. $50
15. R34 GTR Vspec front bar with diffuser just had respray in Bayside blue, lower lip needs another paint. $500
16. R34 GTR Vspec complete front end just had respray in white, this came on the 34 i bought but z tune kit is half here and half in japan so need to make way for it. i would like to sell this one as a complete set, Front bar with lower lip in black and lower diffuser and grills no badges, guards and bonnet. $1200 if to be broken up it will be bar with lip and diffuser $500 guards $350 Bonnet $600
17. R32 GTR Rear bar, has broken tabs on one side $50
18. R32 GTR Carbon exhaust rear bar shield $100
19. R32 GTR Carbon N1 vents $120
20. WGNC34 s1 260RS Front seats VGC $400 for the pair
21. TE37 custom powder coat, they were black when i got them since then i have had them blasted and recoated but am planing on blasting them again and getting them painted in white which is what is on the stickers say. also come with fedrals 595 with about 10000 km left on them $2350
22. R32 GTR intercooler $150
23. R34 GTR Nismo S-Tune Shocks off my 34 pretty sure it will fit on 33 GTRs as well not sure what kinda of condition they are in as i have not driven the 34 yet and i have Tien RS's being built for my car. $600
24. Nismo LMGT4 bronze 18 9.5+12 $2400
There are still a whole heap of items i need to list and take photos of but ill probably have to start a part 2 of items i have for sale, anyways just pm me and ill get back to you asap.thanks
http://s1320.beta.ph...onle88/library/
Is this the rear fork type?
Would this fit S2 RS4S ?
Cheers
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
