I'm selling my bnr34 Greddy air diversion panel and it is still in good condition,i think they are discontinued and the reason im letting it go is that i manage to get the ARC diversion panel.I will do AUD 175 posted.
Nismo kill switch lighter - AUD95 posted
RB26 Transparent timing belt cover- AUD 150 posted (UNUSED NEW)
Edited by shark79
Nismo kill switch lighter - AUD95 posted (SOLD)
this is not fair i have pm the tracking link and ID 2days ago and i just pm'ed you the screen shot after getting your pm . I demand an apology
Edited by shark79
greddy panel tracking id sent as well. no issues there
all parts were sent out 1 or 2 days after payment was made as i needed some time to find suitable packaging so it will arrive safetly
Edited by shark79
http://www.pos.com.m...stered_mail.asp
someone in here can you guys please kindly check if the tracking id and link that i have posted is working.
Thanks
RR147945187MY (tracking id)
enter at reference number and click Track ,follow exactly with capital letters
Edited by shark79
Heads up fellas, I'm still waiting for lighter think we hava scammer ere.
Apologies tracking took 48hrs before active, all sorted once again sorry bout that comment mate.
yes, i did pm you the day i send it out that tracking will take 24 to 48 hrs before its remitted into the system . just to make sure i have email you the receipt as well.
apology accepted, kindly let me know if it arrives safetly.Thanks
Edited by shark79
I've bought a few thinks from Prajash he's an honest seller and able to track down rare JDM stuff with ease. I'll buy from him again. Remember post from overseas to Australia takes time.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
