Recently i upgraded my transmission to Os 1-5 gear set and quad plate clutch.
When the clutch is applied there is a big noise/rattle.Is this normal?
Can't hear the noise in 2nd to fifth maybe on the move and the car too loud??
Has anybody had this issues ? any feed back woud be appriciated.
Thanks
https://www.sau.com.au/forums/topic/418554-os-giken-quad-palte-clutch-noisy/
its more like something is loose
when 3/4 down and in first no rattle .its weird guys at .CRD sayingnothing wrong with it and you have to use it right away. I
like to stay in first when the traffic light is almost green or on the hill :verymad: maybe i just have to get to used to it
when its all the way dow its ratteling.
still running the engine in with nitto 2.7 full stroker kit sump ex,oil pump and CRD race head but stiking with my unknown drop in cams........
so i thought while the engine is out better do the transmission too (8.5k including other nissan parts for gear sets)
next step is big fuel system and presision turbo
400-500 kw mark havent decided yet thats why i went with something big so i dont have to worrie about transmission
Hi Bruce,
Good to see you made it onto SAU and have got the car on the road. Like I may have mentioned to you last year, the quad plate is overkill for what you want and yes, they will rattle. You will get used to it. You have everything engine-wise for 600+kw. Just need a cam upgrade ;)
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
