due to a over eager mod my last thread was locked yes i didnt list prices straight away but was going to put them up when i got home, didnt need to lock after only a couple hours just a reminder to put up prices, i have read the ruls and was in a rush thought i would just put it up to get the ball rolling. hopefully theres enough detail this time.
picked up another r33 gts-t to strip 1995 series 1 its the bluey/green n silver 2 tone
1995 turbo manual
(running gear on hold)
blitz adj coilovers $850
hicas lock bar $60
big straight through exhaust gotta check dump section sounds really nice $350
front strut brace $50
rear strut brace $80
rear brake set up with 5 stud $500
front brakes, calipers/rotors (i have 2 sets) $250 each set
stock diff (will confirm) $150
Half shafts $120 pair
Volk TE37s 18x8.5 18x9.5 +35 offsets 70% front cheap tyres near new 595 federals rear, price im unsure chinese copys 800ish new 3000ish genuine these with lame offsets n decent tyres few marks etc $1800?
complete interior to part:
centre console $80 (will check condition of hinge)
dash surround $100
good condition seats front and rear $250
drivers window switch $80
window regs n rails $150 pair or $80 each
alpine 6x9s $40
some splits in the front (will confirm brand) $60
momo wheel n boss kit $150
let me know what parts you need, will add items when i think of them
located northern suburbs ADELAIDE
may post smaller items
please PM me for number Cheers!!!
  • Replies 60
Posted Images
few more pics....
rear wiper set up sold pending payment
many ppl asking about the wheels i will try get them off this arvo, gotta find some old sockets as they have bloody lock nuts on them and i didnt get the key with the car grrrr
still have some s1 headlights from another wreck $250 the set, the ones on this wreck seem ok to but a bit dirtier, mind you i havent washed it yet :P
stock front bar and reo front bar is damaged, bar indicators fine,
also found a anodies blue rb25 main drive pulley (harmonic balancer replacement) $50
stock dump n front pipe $50
now have 2x stock cooler set ups $50 each
$1600 for volks
$750 for near new blitz coilovers (with stock stuff for trade)
also have a polished surge tank $50 (i need duel outlet for e85)
also may trade any parts for parts i need..
bosch 044 pump, braided fuel lines, suspension parts anything for rb s14 build :P
also forgot to mention that the car has a sunroof which is working perfectly, found out these arent cheap usually 5-800 from wreckers over a grand new. i will say $400 with what ever i can give you to make it work :P
rear strut brace $60
pioneer stereo mp3 with ipod and usb ports at the front $100
series 2 silvers rear wing $30
dash surround $50
seats front and rear good nick slight fade rear $150 the set
sunroof $300 everything you need
full exhaust aftermarkt 1 piece dump/front, cat (unsure if hollowed) 3" (i think) straight to rear muffler sounds really nice can hear running for the next week or so $300
Complete rear brake set up hub/knuckles/lcas/rotors/discs/handbrake set up with cables $400
2ltr polished surge tank $50
offers on all parts listed in original post :P
VOLKS $1500 (need some shitters for car to roll)
VOLK PRICE DROP
had a good once over the wheels few marks 2 rims have dents, one rear like its gone over a bump to hard, and other on the inner side, car still drove fine, so rerolls needed if you want them perfect, tyres are near near 265s 595 federals on the rear abour 80% fronts
****$1300****
a mate has placed a deposit on running gear but said if someone has coin and needs a running gear to let it go and he will get the next one :P $2000 engine box loom ecu clutch red jacket coilpacks feels strong and smooth!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
