  • Replies 63
For those intending to enter the terms and conditions, as well as payment details are available at
http://www.autosalon.org/orderform.asp
If I have read it correctly the cost to enter as a club display is $50 each, but it will cost you more if you want to enter the DYNO CHALLENGE or SPL/ dB DRAG RACING CHALLENGE.
To enter as a club we must have at least 6 cars. (It may pay to have a few in backup as well)
As the club name is critical to how we are grouped it’s important we all use the same name, hence I suggest we use "Skylines Australia" and not abbreviate it to SAU. We will also need power, so if we will need to pay an extra $60.
PS Whats the chance of all enterants getting together to plan this. We can use my place if its OK with all of you. As time is running short, I would sugest we meet either this weekend or next weekend. What are your thoughts?
Guest Miss_Nismo
**** da police .... if we don't take our cars out at all, or sell them and buy falcodores instead, then they win. Yes getting defected sucks, but we can't not live our lives in fear. And as for the 'there will be a defect station here, here and here' .... just look at what DIDN'T happen at drift day (which was supposedly going to be defect city) - I only saw 1 copper all the way home - and he had pulled over a commondore :)
Yeah and if we don't protect ourselves, and get our cars defected, they are also winning. It's a win-win sito for those guys.
By avoiding getting defected, I'm just avoiding a lot of head ****s.
Anyway, I might enter still, just depends on the status of the skyline at the time :cheers:
Guest Miss_Nismo
Excellent Paul :P We've got to have the GT-R represented under the SAU banner!
Having a 'Skylines Australia' display without the almighty GT-R would be a bit like drinking zero-alcohol beer :cheers:
Edit: The only bummer is you wouldn't be able to do a dyno run on the Boost Worx dyno :)  Unless Shaun did the remove shaft option?
Here's the updated list of "potential" entrants:
4door_Sleeper (R33 GTS25t 4dr)
whatsisname (R33 GTS25t)
Envisage (R34 GT-t)
cell (R34 GT-t)
Nightcrawler (S15 200SX)
Steve (R33 GTS25t)
skipppy (R33 GTS25t 4dr)
Clint32 (R32 GTS-t)
Pawley (R33 GT-R)
MattR (S14 200SX)
Miss Nismo (R32 obviously not worth mentioning)
:headspin:
Shutdown
Envisage (R34 GT-t)
cell (R34 GT-t)
Steve (R33 GTS25t)
Clint32 (R32 GTS-t)
Pawley (R33 GT-R)
MattR (S14 200SX)
Miss Nismo (R32 GTS-t *worth mentioning, as it has a special engine*)
Hi Guys
Just got the word that my car is unlikely to be out of the spray shop in time for the show. :-(
This means that there is room for another 4 door :-)
I am still happy to help organise/coordinate this if it’s needed (as I am the one who started this whole thing anyway)
If there is a need for those entering to get together and plan it (or just meet and go for a cruise and talk) my place is still available.
Remember to get your entries filled in soon as there is a late fee for those who register in the last week.
PM me if you have any further questions.
If someone wants to run with this (and help 4door) that would be great! If need be I'll do it, even though I'm a tad busy atm.
Damn it! I just realised that Autosalon is on the same weekend that 'I' want to do go-karting. Bummer ;)
I'll post up a new thread for people to give a, 'yes I am 100% entering AS'
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
