Hi,
I have been reading this forum for quite some time, but i needed to ask a specific question in relation to my particular car.
I have an R34GTR, it has an aftermarket front pipe and exhaust. Hi-Flow cat, yellow jacket coil packs, pod filters, Apexi Power FC ecu, electronic boost controller, Hi- flow fuel pump with a nismo fuel reg and these turbos http://www.ebay.com....=item1c1cadc7d4
It also still has standard injectors and air flow meters.
My question is this, in the cars latest tune, it has only achieved 260kw atw at 19p.s.i boost.
This seems to be low to me considering that the turbos are supposedly rated to flow a lot more power than that.
There is plenty of fuel and the injectors haven't been maxed out.
I haven't got adjustable cam gears on it, i'm wondering if that would help?
But i thought that they would mainly improve mid range.
I have to say though that the car does have fantastic mid range power, but according to the dyno sheet, seems to run out of puff higher up.
(As can be seen on the attached dyno sheet. Its the darker line 260kw atw run. Sorry about the quality)
The exhaust didn't sound restrictive on the dyno, and the car wasnt missing at all and seemed to rev quickly and smoothly.
The engine is also in excellent mechanical condition.
In its previous tune the car achieved around 250kw atw on 1 bar boost with its standard turbos, it wasn't pushed any higher due to ceramic wheels.
What do you guys think?
Any constructive critism would be appreciated.Thanks.
https://www.sau.com.au/forums/topic/419415-r34gtr-tune-opinions-wanted-please/
As per the link - he put R33 N1 turbos onto it.
So a MASSIVE step back in response performance (as evident by boost response), for not a lot more power in top end... Hence why many people view R33/R32 N1 turbos are a downgrade.
Yes they should be making more power, talk to the tuner and fine out what the issue is. Could be 100s of things from cam timing to an exhaust restriction.
The turbos that were on it to begin with were the standard R34GTR turbos with ceramic wheels.
The turbos i have on now apparently are a hybrid combination and have a 60.1mm O.D compressor and the exhaust turbine is 53.0 mm O.D.
Click on the ebay link to see the turbos that are on it now.
The turbos do take a little bit longer to come on, but they do have a stronger mid range with over 20kw atw more power.
But you are right that in the top end they taper out.
I just thought that they would've kept pulling at about the same rate as the factory ones, and kept that advantage right through to the redline.
Edited by johno34
Ye I clicked the link, they are just 1980s N1 turbo cores mate, all the lag of -5s with the peak power of -7s... So the worst part of either turbo really (lag and no proper top end).
You could have had that 20kw more, 500rpm earlier if you got new generation Garretts.. So ye...
Anyway you've got what you've got, and you'll have to deal with it. Either way you still need to get the setup fixed as it should be 30rwkw more peak on around 20-22psi
Yeh i know............coulda, shoulda, woulda. :unsure:
I was trying to improve it on a budget........the car does feel better to drive, and it does feel noticeably stronger mid range.
These factors , plus i got rid of the worrying ceramic wheels, makes it good bang for your buck in my opinion.
They were $1,000.00 cheaper than -7's.
Like you said, they should have have more in them.
Would adjustable cam wheels be a move in the right direction?
My exhaust also has an offset front muffler which may be restricting it as well.
So i might see about taking it out.
Thanks for the input.
My tuner did try increasing the boost, but the power gain in the cars current state wasnt advantageous in his opinion.
i.e not worth the gain from the boost increase, i think he said 4kw for 1p.s.i of boost.
Edited by johno34
Cam gears won't fix the power issue... Your cam timing might be out though... Always fix the setup and get it running right before changing parts and fine tuning it is always a good way to work.
Offset might be a problem, might not. Just drop it and do a dyno run or two. If suddenly more timing/boost goes into it then you have your culprit. It might even increase in power naturally so ensure the tuner is watching carefully.
Could be the tune itself, cam timing yes for sure check and the exhaust for restrictions.
Could be leaky cooler piping or even a case of a rag being left in the cooler piping and semi blocking it somewhere (seen that before). Lots of things to look at really.
i was going to buy those turbos but got highly warned not to touch them. just go big single to4z
:P
Single turbo set up would be nice, but a HUGE difference in price to do it properly! :blink:
I got a quote to change the internals and replace the ceramic wheels on my original standard R34GTR turbos and the price was higher than the turbos i bought.
So in that respect, more performance with steel wheels is a bonus.........i think. :unsure:
I'm not saying that you got ripped off but I paid less than that for my R34 N1's. Pays to shop around sometimes.
I did look around for prices everywhere i could find, obviously i didn't look hard enough.
Where did you get your R34 N1's from for that price, thats very cheap from what i got quoted.
Were they new, re-conditioned or used?
Or........did they fall off the back of a truck? ;)
Edited by johno34
I bought them second hand and then just checked that they were in good condition. I remember I got quoted roughly $1000 each to have my stockers high flowed and steel wheeled. Then I found the N1's for $1100.
Just luck I guess. But I have seen them come up for around the $1500 mark.
Good that you got a good deal.
I didn't really want to buy second hand turbos if i could help it, if anyone was going to buy a dud set, it would be me! :wacko:
Yes, they are expensive to do up with steel wheels and hi-flow, i got quoted $850.00 each to do just that.
What mods and power do you have with your GTR?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
